hey Skyfxl
remember u gave me this thing: runDll32.exe shell32.dll,Control_RunDLL hotplug.dll
it doesnt work anymore. and now i have the same problem, as soon as i unplug my maya my screen turns blue. what should i do? when i use this \"runDll32.exe shell32.dll,Control_RunDLL hotplug.dll \" it doesnt show anything.
tnx
tnx
geposted Mon 11 Feb 08 @ 11:16 pm
RunDll32.exe shell32.dll,Control_RunDLL hotplug.dll should be the exact string for your shortcut
If this doesnt work and your computer keeps blue screening it would suggest that your os is damaged.
Option 1 Do a clean install.
Option 2 : Use Dev Con
http://support.microsoft.com/?kbid=311272
After you've downloaded devcon, run it and bring up command prompt by typing CMD on start menu > Run , type "devcon status *" in a command window. This will generate a list of all the devices on your system. Look for the line which describes your device. In my case of a maxor hardrive
You would type
devcon remove sbp2maxtor
The "*" at the end is a wildcard and matches the manufacturer
so in the case of a maya i dont own one to test the name but it would say maya or esi in the device list
once you know the string save it in a txt document on your desktop and rename it from .txt to .bat double click this any time you want to remove the device.
You would type
geposted Tue 12 Feb 08 @ 5:09 am
Thnx for ur response, but:
1st. when i use this RunDll32.exe shell32.dll,Control_RunDLL hotplug.dll , it doesnt show anything. I have plugged my usb flash, it shows my usb but not my maya.
2nd. i downloaded that Devcon, i unzipped it, run the CMD on start menu, i type devcon status, but doesn't work, (I'm not like u, i don't know anything about computer and these kinda stuff, im studying psychology :) ) so don't expect me to understand what u said. :)
I even reinstalled my maya, but i still get that blue screen. oh i have to say that, not all the time my screen turns blue, sometimes i don't, more often i do get that blue thing. i have tried many ways, like i tried unplugging first then closing its program, or closing the program then unplugging the maya.
there is something here that i don't understand. why sometimes my screen turns blue, sometimes it doesn't?
geposted Sun 17 Feb 08 @ 11:22 pm
Then i think the best option for you would be to do a repair install windows or ask some one to do so for you.
geposted Mon 18 Feb 08 @ 12:52 pm
