running vdj home edition with the hercules mk2 on a laptop without acess to the net.
wish to download professional version,and cant figure out how transfer the new version from pc to laptop.
anywhere i can buy a cd instead of downloading??
thanks in advance
TOMMY VICE CITY
thanks in advance
TOMMY VICE CITY
geposted Tue 12 Feb 08 @ 9:36 am
You can buy Numark Cue, it's the same as VirtualDJ which comes on disc, but If you buy VirtualDJ from this site you will get a good discount as you own a mk2 and the home version.
To get VirtualDJ on your Laptop follow this,
Make a special folder on your PC desktop.
Buy VirtualDJ 5.07, download it ( don't open VirtualDJ yet) and copy/paste it to that special folder or just drag it in.
Burn VirtualDJ on to a disc, then put the disc into your drive of your Laptop and install of the disc to your laptop, enter your serial number from your order and I think you should be up and running
Jimmy b
Jimmy b
geposted Tue 12 Feb 08 @ 9:55 am
You can purchase VIRTUAL DJ on a CD choose a physical copy at the web-store
or as suggested you can purchase numark cue.
Please note updates are distributed from this website.
geposted Tue 12 Feb 08 @ 5:03 pm
If you purchase Virtual DJ , you are entitled to a
discount for owning the console.
geposted Tue 12 Feb 08 @ 5:04 pm
