purchased mk2 and installed drivers and bundled virtual dj v3 on my laptop. hours later, i downloaded virtual pro and now the mk2 only works with the bundled version (version 3 i think..) and, even after i activated it in the "control" configure window, the mk2 doesnt work. it is just serving as a sound passthrough, as the headphones and speakers work through it....how do i get the mk2 to work with my recently downloaded pro software??
geposted Wed 13 Feb 08 @ 11:19 pm
You need to get the latest 2007 hercules drivers.
geposted Wed 13 Feb 08 @ 11:21 pm
thanks man...ill try that.
geposted Thu 14 Feb 08 @ 12:55 am
After you get those drivers go into Virtual dj and set your sound settings to:
Input: None
Output: Headphones
S. Card: 4.1
Select MK2in the dropdown for the mk2.
All should work for u then.
Input: None
Output: Headphones
S. Card: 4.1
geposted Thu 14 Feb 08 @ 1:17 am
