Hi @ all,
just a quick question about this option: I don`t do any scratching (just beatmatching) so this option should be set to "latency" ? Maybe to get some "better" vinyl feeling ? Or does it affect the "normal" (non scratch) sound quality too ?
TIA!
TIA!
geposted Sun 17 Feb 08 @ 8:12 pm
latency is an issue which needs to be balanced as best as possible between two things:
1) responsiveness of the software and control elements (timecode)
2) sound quality
when you crank the latency down (1ms) and the hardware cannot handle it, you will get pop/crackles/stutters in the sound. this is because the hardware is not able to deal with the data quick enough.
do some trial and error testing starting at the lowest latency. with each test, mix two tracks and engage several effects on both channels and push the soundcard to 'fail' by crackling. when that no longer happens, you have achieved the middle ground between sound quality and responsiveness.
there are other options as well that govern the sound quality and are also effected somewhat by latency settings, but on the most part, its the cpu and machine that enables these features. refer to the performance chapter in the manual to know exactly what these are.
2) sound quality
geposted Mon 18 Feb 08 @ 9:52 am
Yes
geposted Mon 18 Feb 08 @ 12:38 pm
2) sound quality
2) sound quality
You got me wrong, my question was about the "Scratch" option (which was answered by djcel). I`m fine with the latency, i can run it at the lowest setting (Rane SL1 / CoreDuo 2200MhZ)
geposted Mon 18 Feb 08 @ 4:37 pm
