Hello,
Is there any way to alter the low cut off?
I cuts too high. It should be arround 100hz where only bassdrum and bass are cut.
Currently it's arround 150-200 if i hear correctly. Around these frequencies, there's also all the instrument's and voice's bass. I need that on my mixing.
Thanks,
Alex
Thanks,
Alex
geposted Fri 03 Dec 04 @ 12:43 pm
          there are a few plugins that might help you a bit, also a very good 32 band EQ plugin
    geposted Fri 03 Dec 04 @ 2:38 pm
