So ive been using numark cue and want to change to VDJ version 5. Is there any way i can keep my cue points? LIke move them to another version? or will i have to set them all again in the new program?
Any help much appreciated..
geposted Mon 18 Feb 08 @ 8:49 pm
If you use a full retail version of cue you are entitled to a free update to cue 5.07 if you add your serial number to your profile or update at numark.com/cue
Cue is the same as VDJ other than the skin.
geposted Wed 20 Feb 08 @ 7:04 am
when you pay for it , you will be set free and it saves all sessions.. let me tell you its worth the time in it self.. wait till you cue in video.. whoo freaking hoooo. bigger then a rock star...
geposted Thu 21 Feb 08 @ 11:04 am
