I'm building a new PC just for Video Mixing and would appreciate it if you guys would look over what I have and get your thoughts.
Processor: http://www.newegg.com/product/product.aspx?item=N82E16819115031
Motherboard: http://www.newegg.com/product/product.aspx?item=N82E16813128059
RAM: http://www.newegg.com/product/product.aspx?item=N82E16820231098
Tower: http://www.newegg.com/product/product.aspx?item=N82E16811119068
Power Supply: http://www.newegg.com/product/product.aspx?item=N82E16817171018
Just missing an audio and a video card now. The Audio card needs to have two RCA Stereo inputs right, so I can use the control vinyl? And then the video card needs to have Video RCA out, and idea's on what to use?
Would appreciate any and all help and if you can try and keep it to stuff on newegg.com
Thanks a bunch!
Thanks a bunch!
geposted Tue 19 Feb 08 @ 11:41 am
you dont need rca inputs, you can use jack inputs with a jack>rca adapter. the more pro-level soundcards dont use rca so dont let that dissuade you from buying it.
on the video card, it depends what you are hooking up to. better video cards will have DVI or HDMI out, and at the very least, get s-video. dont use rca because thats a composite connection which is the lowest quality of all of them (whereas hdmi is highest). you only need to make sure your beamer or whatever you connect to has the same.
geposted Tue 19 Feb 08 @ 8:58 pm
