i was looking around for a USB sound card to hook up my 2 timecoded turntables and mixer, would this sound card work http://cgi.ebay.com/EXTERNAL-5-1-USB-SOUND-AUDIO-BOX-CARD-ADAPTER-OPTICAL_W0QQitemZ140208798669QQihZ004QQcategoryZ31492QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I was thinking of just starting out with a inexpensive sound card then moving up to the maya44 sound card. (saving up money to upgrade to pro) thanks
geposted Thu 21 Feb 08 @ 2:43 pm
Sorry Dude this will not work for time code setup, you must have a soundcard that has 4 inputs for your turntables, and 4 outputs that would to to your mixer. The least expensive soundcard that will work is the Maya 44
geposted Thu 21 Feb 08 @ 11:17 pm
thanks for the help. Looks like i will be getting a maya44.
geposted Fri 22 Feb 08 @ 8:32 am
R U using DJ control MP3 or the DJC MK2? If it the latter, u can use it as a soundcard for timecoded;)
geposted Fri 22 Feb 08 @ 11:18 am
