Anyone know if the mixer "Gemini PS-02 USB DJ club mixer" will work perfectly with virtual DJ. I mean for the crossfader thing.
Go see this ebay link for more details
http://cgi.ebay.ca/New-Gemini-PS-02-USB-DJ-Club-Mixer-2-Port-Kill-Switches_W0QQitemZ350027391590QQihZ022QQcategoryZ101980QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Please help me :D
Please help me :D
geposted Thu 21 Feb 08 @ 9:42 pm
please help !
I need to buy a mixer and virutal DJ fast.
Just wanna make sure they will work together....
Or if you guys can refer me a cheap mixer that works with Virtual DJ, something around 150$
thanks alot
and sorry for my bad english
thanks alot
geposted Fri 22 Feb 08 @ 1:01 pm
The USB portion of this mixer is SOUNDCARD INPUT?OUTPUT only.
It WILL NOT work for timecoded use.
Other than that if you are using it with a controller such as a DMC2, DAC2, DAC3, Hercules DJC, or other MIDI controller then this mixer will work just fine.
It is gemini - and usually gemini work alright but are not as rugged as some of the more expensive brands.
geposted Fri 22 Feb 08 @ 3:55 pm
"It is gemini - and usually gemini work alright but are not as rugged as some of the more expensive brands. "
I swear by Gemini mixers because I see ALL mixers as disposable. I have a Gemini mixer from 1998 that I still use at home. I have replaced the crossfader once. The DJ makes the set, not the thousands of dollars you sepend on a mixer. True, some will help you eliminate the soundcard (not this one or any other Gemini I know of), but if it wont, one mixer is just as good as the next.
geposted Mon 25 Feb 08 @ 6:47 pm
