Hello,
i am beginner here (VirtualDJ HomeEdition)- can anybody tell me how i can make a CD directly from a mix? While creating my mix I set out "burn CD" and "Master" and started recording. Then i "got" (created) a file under C:/programs....with the end ".bin". If i want to use my burning software (itunes or Nero), when asked by this burning program to search for the file to be burned, i can´t find this file in my computer (neither in my music library on itunes nor in my computer). Do i need a special/adicional converter program? This file is only shown under "file" in "burn configuration" in the VirtualDJ program - it´s not shown in my playlist - or let´s say it like that, it´s sored in my playlist with the data where i made this mix, but it shows only the titles which i used and not one mixed version.
I think this is a really basic problem of a beginner - maybe someone can help me?
Thanks/Danke/obrigado
Patrick
Patrick
geposted Fri 22 Feb 08 @ 4:23 pm
U NOT THE ONLY ONE I HAD IT FOR YEARS STILL CANT DO
geposted Sat 31 Mar 12 @ 7:50 am
4 year old thread
Locked
Keith
Locked
Keith
geposted Sat 31 Mar 12 @ 7:54 am
