Last night during my little gig, in the middle of playing one of my tracks the audio starting to fade out by itself, and then all of a sudden the sound cutoff............ I had to go into config and actually click on the audio config to enable it again............ Does anyone have any idea???
Thanks
Los
Thanks
Los
geposted Sat 23 Feb 08 @ 4:35 am
Hi Los sorry to hear of your problems.
Some quick questions , are you using leopard or tiger? Are you using 5.07 [cue] ? Which sound-card do you use?
geposted Sat 23 Feb 08 @ 9:45 am
not sure what is leopard or tiger?
I'm using 5.07 cue
I have the numark DJ IO Sound Card
Thanks
I'm using 5.07 cue
Thanks
geposted Sat 23 Feb 08 @ 4:41 pm
Ok go to Apple > About this Mac and it will tell you what version of Osx you use.
If you use 10.5 :
Unfortunately the drivers for the DJ/io are not 10.5 compliant yet testing is underway of a new driver.
If you use 10.4:
Which mac do you own? if you own a macbook white or black ensure you have the latest updates for Osx as there are issues with the usb ports on these models which have been addressed in updates.
If you use 10.5 :
If you use 10.4:
geposted Sat 23 Feb 08 @ 5:01 pm
I Have version 10.5
2.6 Ghz Core 2 Duo
4 GB 667 Mhz
Is there a place where I can learn more about the mac and numark?
Thanks
2.6 Ghz Core 2 Duo
4 GB 667 Mhz
Thanks
geposted Sat 23 Feb 08 @ 6:03 pm
Ok a driver update will be released soon for your version of osx this will resolve the issue.
You can learn more about numark products on mac at the numark forum.
http://forums.numark.com/forumdisplay.php?f=23
geposted Sat 23 Feb 08 @ 6:34 pm
Thanks alot for the information
your boy Los
your boy Los
geposted Sun 24 Feb 08 @ 1:25 am
