I was wondering if there was a way to put my company logo on VDJ so that it shows on the video screen while playing videos?
Thanks for any input.
geposted Sun 24 Feb 08 @ 1:27 pm
yes there is.
picture slide show
picture slide show
geposted Sun 24 Feb 08 @ 2:02 pm
Use the SHOWLOGO plugin. Works great
Funkmasterfrank
Funkmasterfrank
geposted Sun 24 Feb 08 @ 2:04 pm
So there is no way to change the default logo of VDJ to our own and have that show up?
geposted Sun 24 Feb 08 @ 3:24 pm
Yes you can disable the VDJ logo , in Config > Video
and then you need to use the Show Logo Plug in which will allow your logo to be displayed on the video you can use transparency as well if your logo has a white background and you enable the transparency mode only your actual logo will show like on MTV.
geposted Sun 24 Feb 08 @ 3:38 pm
SHOWLOGO is great i use it all the time.
My favorite thing to do with it is to make the my logo transparent and overlay on the videos.
this kinda makes my logo look like a watermark.
geposted Sun 24 Feb 08 @ 4:44 pm
I've made my logo using a great program that's just like Photoshop
Best of all it's FREE
www.getpaint.net
By the way, I think that placing your logo on the screen (e.g., top left corner) while a video is playing is called a "Bug" in video editing lingo.
www.getpaint.net
geposted Sun 24 Feb 08 @ 9:04 pm
