HI.
Can somebody that have teh players share the expirence with VDJ ?
i know the screen dont work (need native support) and that they are not ready for windows vista (layer drive inssues).
In XP should be work as a external sound card (diret no asio) ! true ?
come with drivers in the box ! true ?
VDJ team are working on a native support ! true ?
it work with no problems in MIDI MODE and all bottons send a MIDI SIGNAL ! true ?
well i hope to have soem news
thanks in advance
DJ CHOPIN
thanks in advance
DJ CHOPIN
geposted Mon 25 Feb 08 @ 6:11 pm
I don't have them but do take a look at this link:
https://virtualdj.com/forums/82610/Hardware_Technical_Support/PIONEER_CDJ-400___VDJ.html
And if you are a "PRO" user this was posted by MOSHI...
Pioneer CDJ-400 "BASIC" midi control released !
https://virtualdj.com/addons/view.html?type=tool
Description:
set cue = pusch the wheel
goto cue = pause & cue
sync = tempo
loop in & loop out
beat loop & reloop exit
zoom
search
reverse
Description:
sync = tempo
loop in & loop out
zoom
search
reverse
geposted Mon 25 Feb 08 @ 6:28 pm
In addition you can add more functions if you want since it is a midi device :)
geposted Thu 28 Feb 08 @ 12:27 pm
