I like using vdj in collab with my hercules DJ console. But when I'm touching some of the buttons (bass, treble, the jogwheels..) i hear a kind of scratching in the background. I really don't know what it is. Some help?
Second problems is that sometimes, in the middle of a mix, one of the records is fwding, of going backwards, with me even touching anything.
Does somebody have an idea what this could be?
thnx
thnx
geposted Tue 26 Feb 08 @ 5:19 am
Me and my friend also have the first problem you got, I'dd like to know how to fix this :D
geposted Tue 26 Feb 08 @ 6:54 am
What version u guys using?
geposted Tue 26 Feb 08 @ 1:01 pm
I'm using V5 Rev 7, and my friend uses V5 Rev 6
geposted Wed 27 Feb 08 @ 3:33 am
Hi Link2088, Try the latest demo. Remember to uninstalled ur version first then installed this.
Then set the performances slider to fastest n latency auto. Untick both overclock n safemode.
Also what is ur system specs n r u using herc mk2 as soundcard? Updates the drivers.
If u have the pro version, do kindly register it at ur modify ur profile and grab the goodies available for u;)
geposted Wed 27 Feb 08 @ 10:29 am
Thanks spinnaJ, the sounds are gone ;)
I've got 1,83 GhZ Duo Core (so 2 x 1,83Ghz) and 2Gb RAM. I use the ASIO driver.
But I guess this doens't matter anymore since the problem is gone now :P
geposted Thu 28 Feb 08 @ 2:11 am
Good!
Hope to see u as a pro user soon;)
geposted Thu 28 Feb 08 @ 11:23 pm
