I have 2 new mac book pro's (2.4 duo pros. 4g ram nevidea 8600 256)
I installed my maya44 usb sound card and i can't get it to play stereo out. in the drop down menu of vdj it is only giving me the option for mono split, 2 cards and 4.1...and the only 1 that it will work with is the mono split.
is there a driver for the maya that i need to install to make it work correctly?
i just switched over from pc and never had any problems before. this is my first time with a mac. i've never even touched a mac before so i really don't know what i'm doing.
any help you could give me would be greatly appreciated.
geposted Thu 28 Feb 08 @ 1:31 pm
Hi thefallguy,
Firstly I envy your 2 new mac book pros!!!
I don't know about the Maya44, but you can try this:
Go to this topic:
https://virtualdj.com/forums/85051/MAC_Version_Technical_Support/Maya_44_USB____VDJ_5_0_7.html?highlight=Maya44
Hope this helps.
Enjoy your MAC!!
Go to this topic:
Hope this helps.
Enjoy your MAC!!
geposted Thu 28 Feb 08 @ 4:11 pm
