Creating a skin, can i have the VDJ logo on its side, what are the options here, I understand I need to include it (in the xml not as bitmap) - what are the options - Can I change it's colour ??
geposted Fri 29 Feb 08 @ 8:52 am
its hardcoded into the program , it can be any where on the skin and any size, via coordinates in the skin , you cant change its colour
geposted Fri 29 Feb 08 @ 10:41 am
Thats what I thought, thanks.
geposted Fri 29 Feb 08 @ 12:24 pm
what if it doesent have the logo on the skin?
geposted Thu 13 Mar 08 @ 12:22 pm
I think the Skin or VirtualDJ won't open and it will chuck up a Error.
Jimmy b
geposted Thu 13 Mar 08 @ 12:28 pm
Yes, and it has a minimum size, that you can get off just about anyones skin, and few make it bigger than needed.
If its not in there, it "Error in line 0 of the XML"
geposted Sat 19 Apr 08 @ 5:56 am
the first post i make in this forum, with some actual programming info, gets deleted... and you wanna beat serato... keep jerkin' off to that thought.
geposted Mon 05 May 08 @ 5:10 am
No posts have been deleted...some posts which from time to time contain content considered questionable, or with data VDJ does not want available to the general public get leveled up. But out right deleting is a huge No-No for us here. That being said, please be more respectful. Rude behavior is one of the things that is not tolerated here, please consider that a kind warning.....T
geposted Mon 05 May 08 @ 7:32 am
And your *contribution* was a HACK to the code to circumvent a requirement by using our application. We do not tolerate the warez, cracks and hack posts.
geposted Mon 05 May 08 @ 11:12 am
