If like me you own a BCD3000 and have had problems getting it to work in ASIO driver mode please read this.
Problems include:
-VDJ Not responding after a certain time period
-Playback slows down loads and becomes muted.
-Headphone mix function not working
Well there is a simple fix. After reading throug the Native Instruments forum and discovering that users of Traktor 3 were having the same problem with the BCD3000, I deduced that this must be an ASIO driver issue; not a software issue. To fix this problem, simply disable your anti-virus and ANY network controllers and you should be fine. I have done this and have'nt had a problem since. Also, uncheck safe mode in performance options because that was causing me some slight crackling (i think safe mode is meant for low spec machines and can have adverse affects on higher end machines).
I hope this helps other people, it took me hours to come to this conclusion :)
Problems include:
geposted Fri 07 Mar 08 @ 7:20 am
