Why if i set the pitch with one song when i put the next song on it gos back to normal
geposted Mon 13 Dec 04 @ 6:07 am
by design
geposted Tue 14 Dec 04 @ 10:52 pm
this can be turned off from version 2.06
there is an option for disabling pitch-reset from this version on...
Try the new 2.06 demo, turn off auto-pitch reset, and auto-bpm, and you will see that the pitch do not go back to zero when new song is loaded
hope that helps ;)
hope that helps ;)
geposted Thu 16 Dec 04 @ 9:45 am
