I just purchased a MacBook Pro (2.5 duo, 2gb, 250gb, 512mb Nvidia 8600). Here is my question. I am wanting to run Virtual on my bootcamp (XP Home) partition so that I can use my AVI files. I have the bootcamp as a FAT 32 so that I can share info with my Mac partition. I need an adaptor that goes from the DVI to video (S-video and/or composite) mainly S-Video. I purchased the adaptor from the Mac store and it works great on the Mac side but nothing on the Windows. Any suggestions for a good adaptor that is just plug and play and does not need a bunch of adjustments to look good.
I love the performance and would like to use this computer but video is huge for me.
Thanks,
Chris
P.S. These Macs are cool!!!
Thanks,
Chris
geposted Mon 10 Mar 08 @ 2:36 pm
Hi...what version of vdj r u using? I was unaware that avi files didn't play in current version. I played a small avi file (wasn't a music video) but it played.
geposted Mon 10 Mar 08 @ 8:16 pm
I use the 3ivx codec and I figured from reading other posts that it will not play in the Mac version. I just have too many videos to convert them again, since it does work on the pc version. I am using 5.0 7
geposted Mon 10 Mar 08 @ 9:25 pm
You mentioned that you read...have you actually tried ur files yet? sorry if that seemed like a dumb question but you didn't mention you actually tried.
geposted Mon 10 Mar 08 @ 9:31 pm
No, I actually had not. I will try installing the Mac software version and see what happens. On another note can you use the gigaport and iCdx with the Mac version?
Thanks,
Chris
Thanks,
Chris
geposted Wed 12 Mar 08 @ 8:58 am
Okay, I cannot use the Mac version because all of my external harddrives are NTFS and I cannot write to them to update the database. So back to a video adaptor that will work. Any other ideas would be great.
Thanks,
Chris
Thanks,
Chris
geposted Wed 12 Mar 08 @ 1:06 pm
One more thing, are there any asio drivers for the gigaport ag for Mac Os X? I could not find them on the ESI website or googling it.
geposted Wed 12 Mar 08 @ 1:08 pm
Thanks,
Chris
Thanks,
Chris
VDJ 5.07 can read and write to NTFS
so can osx 10.3+
geposted Wed 12 Mar 08 @ 3:24 pm
Asio doesnt exist for mac its core audio , if the main os picks it up in audio and midi setup applications > utilitys > audio midi setup you should be ok
geposted Wed 12 Mar 08 @ 3:25 pm
Thanks,
Chris
Thanks,
Chris
The ICDX works fine.
geposted Wed 12 Mar 08 @ 3:26 pm
so can osx 10.3+
I have not tried it but when I select file info on the drive from the Mac os I get that permissions are read only. Am I doing something wrong or will VDJ write to the external NTFS drive even though it says read only?
Thanks,
Chris
so can osx 10.3+
Thanks,
Chris
geposted Wed 12 Mar 08 @ 9:24 pm
In finder get info on that drive and manualy change the permision for the drive to Read and Write
geposted Thu 13 Mar 08 @ 4:45 am
I cannot change the permissions on my NTFS drive, it does not have that option. I am missing something?
Thanks,
Chris
Thanks,
Chris
geposted Thu 13 Mar 08 @ 12:05 pm
Okay, once I started VDJ the drive then became able to read / write. Now, my gigaport shows up but all of my music plays through channels
1 & 2 on the gigaport. In settings I have Driver 1 as gigaport ag and driver 2 as the same. The I have player 1 to left deck and 2 to right. Any ideas?
Also, loading a song is very slow, compared to the PC version.
Thanks,
Chris
Thanks,
Chris
geposted Thu 13 Mar 08 @ 2:24 pm
https://virtualdj.com/forums/70794/MAC_Version_Technical_Support/Tweaks_to_the_mac_configuration_file__(similar_to_registry_changes_on_pc).html
Hi there you should try the speed load trick.
By default tracks are loaded slowly to protect slower macs.
Click my name for a blog to make an aggregate device .
geposted Thu 13 Mar 08 @ 3:40 pm
