hello i was just wondering i have brought some oldish decks kam beltdrives100 and i need to know weather i can connect my turntables or numark mixer to my hercules dj consol mk2 withut having to run a pc or laptop?????
geposted Tue 11 Mar 08 @ 5:26 pm
Mk2 isnt a mixer , its a soundcard you would need to buy pro to use an external mixer.
geposted Tue 11 Mar 08 @ 6:01 pm
ive got it already
geposted Tue 11 Mar 08 @ 6:16 pm
Please add your serial so you can get the latest version which supports it.
geposted Wed 12 Mar 08 @ 4:32 am
ok will do
geposted Sun 16 Mar 08 @ 11:09 am
mk2 is not a mixer? its supposed to be a soundcard, controller, and a mixer isnt it? according to steve sharp it is haha.
If you use an adapter from your mains to the mk2 it shoud work as a normal mixer without the use of virtual dj/computer and its USB
geposted Sun 16 Mar 08 @ 7:34 pm
