virtual dj is not working o n my system (none of the versions) its showing protection error, anyone has a solution it will be greatly appreciated.
geposted Wed 12 Mar 08 @ 8:51 pm
did you get the trial version from download centre,? if so uninstall that copy and download new copy, i take its a crack your trying to install by saying "versions" then follow the first step, you don't know what viruses your putting on your system with that stuff get rid of it and find out how good VDJ really is instead of using sub standard software
Tayla
Tayla
geposted Wed 12 Mar 08 @ 9:02 pm
A protection error usually means you are running a "cracked" version of VDJ. Either download the trial and deal with it's limits or purchase the full version.
I would stay away from any "version" you might download from Limewire or a Torrent. VDJ is a great program and there is enough evidence here in these forums to support that. So I can recommend you buy a full licensed version, you'll be glad you did!
Sir Wesley
Sir Wesley
geposted Thu 13 Mar 08 @ 2:49 am
yeah thanks guys!! actually i got it frm a friend of mine, i don't no where he got it but it use to work until i formated my system it hasn't since then... I'm using 4.0 and i really need this shit i need to record a new CD, it setting me way back.
geposted Sat 15 Mar 08 @ 12:15 pm
Its because its a cracked version or illegal sharing of serial, sorry.
You can always buy your own legal licence here:
https://virtualdj.com/buy/
geposted Sat 15 Mar 08 @ 12:21 pm
