Is it worth it to get the 7200 RPM speed drive or should I stick with the 5400 RPM? Also, would an NVidia card with only 256 MB of RAM be okay?
geposted Thu 13 Mar 08 @ 10:19 pm
I'd defenitely go with the faster hard drive speed...it makes accessing the data much quicker.
256mb ram is fine...providing it's a dedicated (i.e not integrated) graphics card.
P
P
geposted Fri 14 Mar 08 @ 5:19 am
Is the faster drive speed that important? I'm having trouble finding a laptop I like with a 7200 RPM drive that doesn't cost me an arm and a leg.
geposted Fri 14 Mar 08 @ 1:26 pm
Well it is important but the snag is if you find a cheap high speed one it can fail quicker as the cheap parts wear out.
geposted Sat 15 Mar 08 @ 7:10 pm
A 5200 rpm drive is faster than a USB2.0 external with a 7200rpm. Don't spend the money! Buy something cool.... like a larger drive. Don't forget, as the density of the platters increase, the data transfer rate increases without spinning the drive faster.
Also, I was running VDJ 4.X on a system built in 2002 with a P4 1.7GHrz processor and an NVIDIA 5500 video card, flawlessly… Out just about every week end. (DJing since 1986, Fully computerized in 2000)
Don’t let the “Hot Rod” crowed influence your decisions.
geposted Wed 19 Mar 08 @ 7:11 am
