I'm running Cue 5.07, and have tried 5.06 as well.
I'm on a Vista OS and everytime I go to hit configure my program freezes. It was working, untill maybe I installed some new stuff like a m-audio midisport. Also working fine on my XP setup. Not sure what the problem is, but I'd like to use the Vista pc since it's way faster.
Any ideas or solutions would be appreciated.
-thanks
-thanks
geposted Fri 14 Mar 08 @ 1:40 am
I wish I could help more, but I don't use vista. One thing to try is to remove whatever it was you installed recently, or revert to a restore point and retry, then see if reinstalling the new stuff recreates the problem.
geposted Fri 14 Mar 08 @ 2:03 am
Nevermind
It works afterall. It's just going extreemly slow to load config. I'm going to try to clean up my pc and see if that helps.
geposted Fri 14 Mar 08 @ 5:52 am
Glad you worked it out ;)
geposted Sat 15 Mar 08 @ 12:46 am
