Greeting to all...now were do I start from
I have just purchased a brand new Acer Aspire 7720G laptop installed with Vista. Ihave only installed the demo version of VDJ and already i have encountered problems. Starting up VDJ and loading tracks are ok but once i start the track, after about 30 sec VDJ starts to lag and a crackling noise is heard. Im wondering if this has to do with the laptop running on Direct X 10???.
geposted Fri 14 Mar 08 @ 8:52 am
Search for Vista threads. Vista works fine with VDJ
geposted Fri 14 Mar 08 @ 9:01 am
Try cliking Hardware Acceleration back one line. It helped me on xp, pretty sure is the same on vista.
Hope that helps,
Take Care
Hope that helps,
Take Care
geposted Fri 14 Mar 08 @ 1:09 pm
Try performances slider to fastest, uncheck safe mode n overclock n latency auto.
geposted Fri 14 Mar 08 @ 2:10 pm
You also have to remember that you bought a computer from the store pre loaded with Vista and a ton of crap that isnt needed. I would go through and get rid of all the uneeded crap.
geposted Fri 14 Mar 08 @ 2:39 pm
