really slight ......when i click on the video effect "titler" it launches titler AND sonique ???? doesn't do any harm but just seems strange
this is on 5.0.6 ..... haven't had much chance to dl .7 just yet , hope to maybe this week
os is xp media center edition.......
geposted Mon 17 Mar 08 @ 11:29 am
Audio only track?
If you enable the always apply this effect to audio track option in config > Video , when you enable the plugin for an audio track it will do both.
geposted Mon 17 Mar 08 @ 11:44 am
thanks Sky , i always enable that option , just hadn't noticed b4 , usually enable sonique first ........then other plugins , never saw one plugin seem to launch another .....
geposted Mon 17 Mar 08 @ 11:52 am
Does that titler work correctly for you? When it retracts, it cuts off the beginning of the title, on the output to the TVs. It is OK on the VDJ interface.
geposted Mon 17 Mar 08 @ 11:56 am
Its to do with layers so when you run an audio file with that option selected it always loads Sonque first then titler on top same with any other plugins.
--------------- Overlay FX (titler)
--------------- Base FX (sonquie)
--------------- Source File (audio)
geposted Mon 17 Mar 08 @ 11:57 am
