I dont know what happened i had all my songs analyzed for a good while now and when i went to open my vdj today all the bpms were gone as well as my cue points. I got some popup that said something about their being an error on my drive or database not sure which 1 . I have no idea what happened can som1 please help
geposted Thu 20 Mar 08 @ 3:03 am
Yep, that's pucked up. What version are you using?
geposted Thu 20 Mar 08 @ 4:55 pm
does vdj or cue place the cues in the files...???
geposted Thu 20 Mar 08 @ 5:57 pm
It's stored in a database stored on each drive used. This way you can go any where and use multiple VDJ systems and never lose your work.
geposted Thu 20 Mar 08 @ 7:22 pm
@djchu
Try using the fix button for the drive that your database is on under config>browser tab and see if that does anything.
geposted Fri 21 Mar 08 @ 1:00 am
Did you lose ALL or just some or a lot. There is a difference if you lost ALL>
geposted Fri 21 Mar 08 @ 10:43 am
Are you using an external (usb, firewire) drive?
Ewout
Ewout
geposted Fri 21 Mar 08 @ 12:26 pm
"RECURSE" the drive. When you connect up, locate the drive in the browser window and simply right click, then select recurse.
This has aided me when I've had songs missing and goofed up information on my database.
Hope it helps??
Hope it helps??
geposted Sat 22 Mar 08 @ 9:11 am
fatkatz i lost most.
geposted Mon 24 Mar 08 @ 12:14 pm
john i went into browser and rightclicked my drive and no options came out
geposted Mon 24 Mar 08 @ 12:18 pm
What have you done so far so we don't go through steps again or you might have missed a step / process?
geposted Mon 24 Mar 08 @ 12:19 pm
ok i found the recursing option but nuthin happens.
geposted Mon 24 Mar 08 @ 12:22 pm
fatkatz i really havent done n e thing but tried to recurse the drive. other than that i feel like im gonna end up doin everything all over again
geposted Mon 24 Mar 08 @ 12:34 pm
btw im using virtual vinyl...version 5.0 rev 2
geposted Mon 24 Mar 08 @ 12:40 pm
discjockeydoc wrote :
@djchu
Did you do this?
geposted Mon 24 Mar 08 @ 12:45 pm
cstoll wrote :
Additional ways of doing the old Local Database
Name: Local Database - Analyzed
Filter: isscanned=1
Name: Local Database - Not Analyzed
Filter: isscanned=0
Name: Local Database - ALL
Filter: isscanned=1 or isscanned=0
Filter: isscanned=1
Filter: isscanned=0
I have no clue as why this happens but when your system creates an error it will cause loss of info. That's why I created these filter folders.
I've done this to catch the unscanned files as well as created a search database like the old versions. Try the isscanned=0 in creating a filter folder. ALSO try to browse > clean > fix in the config
So what was the outcome so far?
geposted Mon 24 Mar 08 @ 5:14 pm
its really frustrating..i mite jus do everything over
geposted Tue 25 Mar 08 @ 1:07 am
Dude, I created errors from different ways of doing things incorrectly. I lost info on each situation. Sometimes I lost BPMs or I lost the ability to have it search in the database or both. In every situation I had to redo those songs. That why I created the folders as I stated above to catch those straglers.
geposted Tue 25 Mar 08 @ 3:26 am
