Go to www.tinypic.com upload a picture then get the "forums code"
will look like
make sure your BB code option is set.
will look like
geposted Sun 13 Apr 08 @ 4:54 am
Hi macadocius, yes u could use skyfxl advised on how to post it or if u have any problem do look at my blog on how to do it.
N yes just make sure the BB code message format is chosen.
Regards;)
Regards;)
geposted Sun 13 Apr 08 @ 1:15 pm
this is the turntable to input
geposted Sun 13 Apr 08 @ 9:18 pm
this is the pass to phono
geposted Sun 13 Apr 08 @ 9:21 pm
this is the output to line
geposted Sun 13 Apr 08 @ 9:23 pm
The turntables should go into the phono input channel.
The mixer should be connected to outputs 1 for left and 2 for right.
Pass will literally passout to the outputs.
Please set the input slider to phono.
On the mixer choose line.
geposted Mon 14 Apr 08 @ 2:14 pm
Yeah that should be the right set up;)
This time u surely will get the signal from the vv box.
geposted Mon 14 Apr 08 @ 2:22 pm
so based on my pictures is everything connected correctly? does anyone know if serato conflicts with virtual vinyl if on the same computer.
when i use serato no problems. when i use virtual vinyl i get timecode issues and other error messages. i'm wondering if thats causing problems.
i got a timecode signal for about an hour and now i have issues again with virtual vinyl.
geposted Mon 14 Apr 08 @ 4:05 pm
I haven't upgraded to MacBook yet. Does TC works with PowerBook G4? I experience similar problem with the MacBook users, everytime I try it, it send back the same exact error mentioned.
geposted Mon 14 Apr 08 @ 8:56 pm
G4 probably wont cut it you idealy need a dual core processor.
geposted Tue 15 Apr 08 @ 3:34 am
Follow skyfxl post above my last post on connecting ur VV box. N i assume u already done this n have the signal tru;)
1. I dun think having VV n serato will have conflict. Maybe some guys here using both will give u more input on this.
2. Using serato no problem cos it locked to its interface n u can't use any other soundcard with it, hence it functions good n at it maximum capability. As for the VV, u can actually use other card too other than the numark box which currently hold the best advantage using it as timecoded on the mac version. It just a matter of the setting n ur configuration n once u get it, all will be well.
3. So u have ur timecode lost after an hr? U can just pressed auto config again without needing to stop the music. Also can u try with different cart, if possible and maybe check any connection (RCA) not loose.
In addition in ur config in VV. Try latency auto n slide the performance to best. If best not possible, move it to the left each time until it is.
Regards;)
geposted Tue 15 Apr 08 @ 2:03 pm
ok i want to double check. where does pass on vv box connect to on the mixer? where does output on vv box connect to on mixer?
geposted Tue 15 Apr 08 @ 8:52 pm
Has anyone seen this error message and know what it means
geposted Tue 15 Apr 08 @ 10:07 pm
Yo Guys I have the same problem with My Mac Book Pro an VV. After 30 min of using it my the TC continues to spinn on the screen but I have no control. I have only 1 gig of ram could this be the issue? Can I post a vid on this form to show you?
geposted Thu 17 Apr 08 @ 12:05 am
I get that too but it has zero effect on anything..I get it when switching from straight laptop sound card to vv box but mine works perfectly;). Post a vid forsure if you can!
geposted Thu 17 Apr 08 @ 9:42 pm
Dont worry about that message is is displayed in error there is not an actual problem this is set for the next fix release.
Dont forget you can take a screenshot on mac by pressing Apple Shift and 3
geposted Fri 18 Apr 08 @ 4:16 am
I have too the problem about to configure the timecode vinyl with my MacBook Pro with 2 gb of memory, i have VDJ ver 5.0.7, my soundcard is ESI Maya44 USB.
I usually did the same work like on my PC, that works perfectly. Instead on my MacBook Pro still gives the message "No timecode signal found. Please play a timecode vinyl on the turntable and try again.
If is still not working, check your cables and the volumes of your soundcard", when i press the button "Auto-config" on "Time-coded vinyl configuration".
From the turntables (Technics SL-1200MK2) i plug the cables to the inputs of Maya44 and from the Maya44'outputs to the mixer (Vestacs PMC06 Pro). I put the volume of the Inputs and Outputs to the maximum on "Maya44 Control Panel" and i configure on "Audio devices" MAYA44 USB like a default soundcard. But when i play the vinyl still the message is showing.
Please help me, king regards.
geposted Sat 19 Apr 08 @ 1:27 pm
Did you try configuring it as an aggregate device click my name for a guide on this.
geposted Sat 19 Apr 08 @ 2:42 pm
followed spinnaj last recommendations, slide latency to best and set it to auto. it worked for about six days no problems
and now we can't find timecode again.
geposted Tue 22 Apr 08 @ 3:58 pm
Hi macadocious, do u mean it don't have the signal 100 percent or there none??
geposted Wed 23 Apr 08 @ 12:45 am
