I had to reinstall this version (which is actually Cue) and the new install will not save the DB or the config options. Every time I start it up I have to reimport itunes plalists, and re populate my database. Its not even saving the BPMs. Also, When I put my music in the system, none of the artist names are showing up, whereas they used to show up. Could anybody help me with this?
Thanks
Thanks
geposted Sun 23 Mar 08 @ 3:34 pm
Is there not a single member of support who can help me out with this?
geposted Mon 07 Apr 08 @ 6:35 pm
Hello , My name is Simon i work for Numark.
You should do a hard reinstall of the program by deleting the PLIST file.
yourcomputer/users/youname/libary/preferences
its called com.atomixproductions.cuele.plist
Then trash the main aplication and reinstall.
geposted Tue 08 Apr 08 @ 5:22 am
I did that. Still having the same problem.
geposted Tue 08 Apr 08 @ 4:21 pm
Just gonna try it again.. hard reinstall, and its still not saving my information. Anybody have any suggestions, or are they forcing me to buy the pro version because this one flat out doesnt work?
geposted Thu 10 Apr 08 @ 6:42 pm
Please check your disk permission for that folder perhaps you have set it to read only.
Click on the folder and then in finder choose get info and ensure that you can read and write to Numark Cue in Documents.
geposted Fri 11 Apr 08 @ 7:06 am
