Gang -
I used VDJ for my last two events. 1st was a basic event (background music) and 2nd was a wedding.
1st thoughts... I was very nervous and unease. Been using old red since 2001. I WANT VDJ to work and be my only tool.
How can I get the autocue to line up to the 1st sound (skip past the silence)? PCDJ has a threshold setting.
How does one set a cue point aka standard means? I am using the DMC-1 and optional plugin for it.
Waitlist - is there an easy way to manage it vs the side list?
Anything else that would help?
Thanks gang!
Thanks gang!
geposted Sun 23 Mar 08 @ 8:04 pm
ewitles wrote :
Gang -
1. How can I get the autocue to line up to the 1st sound (skip past the silence)? PCDJ has a threshold setting.
2. How does one set a cue point aka standard means? I am using the DMC-1 and optional plugin for it.
3. Waitlist - is there an easy way to manage it vs the side list?
4. Anything else that would help?
1. in the playlist click on the + symbol > "automix type" >"fade (remove silence)"
2. i don't use the dmc-1, so i can't tell you.
3. waitlist, nope.
4. learn to use the keyboard and the loop functions.
geposted Sun 23 Mar 08 @ 9:08 pm
Thanks -
I saw the playlist automix setting but not what I'm looking for. When I load either player, I have to manually set the cue point.
Maybe this could be a 'feature' for the next version?
geposted Sun 23 Mar 08 @ 9:14 pm
you need to set the cue points once on the track and it will remember it.
geposted Sun 23 Mar 08 @ 11:13 pm
An easy way to set cue point is to get the track cued to where you want to place the cue point, then press the CTRL key plus the a number. For instance to place one of three cue points press CTRL-1, CTRL-2, etc...
geposted Sun 23 Mar 08 @ 11:21 pm
