Hey guys..
I am about to order a new mixer. Will i have any problems with this mixer? Will it connect just fine to Maya 44 USB ?
Just wondering cause on this time code vinyl guide i got for Virtual DJ seems like the RCA cables are connected to analog out into the back of the mixer "CD"
I am trying to explain this the best of my knowledge...
This stuff is rather confusing to me..
geposted Fri 28 Mar 08 @ 7:53 am
If you are buying a 'NEW' mixer, I assume you already have one, the hook-up should be the same.
The level that comes out of the Maya is a Line level signal. That is why it shows going into the CD/Line input on the mixer.
BTW, which version of VDJ are you using ? The VDJ 3.4.1 for the MK2 does not support Timecode but for 5 minutes. You need the Pro Version to take full advantage of Timecode use.
geposted Fri 28 Mar 08 @ 8:25 am
Well i downloaded the Trial i have 13 days left this is your latest version of VDJ
I was just curious the last mixer i had it was a "dud" Guitar Center sold me
a new one but it was damaged, my last mixer was a Stanton SMX 201.
So i didn't get a chance to use it with VDJ....
geposted Fri 28 Mar 08 @ 6:26 pm
Ok, well as I mentioned the graphic is correct and you should hookup the outputs from the soundcard to the CD/Line level inputs on the mixer.
geposted Fri 28 Mar 08 @ 11:10 pm
