Hey all,
I have Virtual DJ v4.2.
Lately, when I'm playing music, it just freezes on a song, get stuck and just repeats the last 10 secs.
I have to "End Program" it after that. Its been happening more and more often.
Appreciate any suggestions you may have..
thanks!
Leo
thanks!
Leo
geposted Fri 28 Mar 08 @ 7:51 pm
Please post your system specs and is this a trial version of VirtualDJ?
geposted Fri 28 Mar 08 @ 7:58 pm
I have Windows XP and 2G Ram. any other specs you need?
Its not the trial version either
geposted Sat 29 Mar 08 @ 1:16 pm
Hard drive size, and CPU speed would be helpful.
geposted Sat 29 Mar 08 @ 3:19 pm
40G hard drive & Intel Pentium 4 CPU, 3.00Ghz
geposted Sat 29 Mar 08 @ 4:18 pm
Your Hard Drive is on the small size, but you should be able to run VDJ. I would try to un-install the older version your using now, and download and try the trial version. See if that helps...
look here for system requirements https://virtualdj.com/products/virtualdj/
And here for the trial https://virtualdj.com/download.html
geposted Sat 29 Mar 08 @ 4:41 pm
thx for the advice tearemup
but then wouldn't i have to buy the new version again after the demo period is over?
geposted Sat 29 Mar 08 @ 4:56 pm
The new version is V5r7, so your using a very old version. Register your serial number and upload the latest version......
geposted Sat 29 Mar 08 @ 5:10 pm
