Buenas,
Estoy valorando la posibilidad de comprar una máquina nueva para mis mezclas y no tengo claro qué máquina comprar. Mi pregunta es la siguiente: A igual velocidad de reloj ¿qué procesador ofrece mejor rendimiento con el Virtual Dj? ¿Intel ó AMD?
Gracias!!!!!!!!
Gracias!!!!!!!!
geposted Mon 31 Mar 08 @ 2:49 am
I'm so sorry... I made a mistake.
The question should be in english, but I mistake the forum... The question
Which processor it's better for Virtuaj DJ??? An Intel or an AMD processor??
Thanks!!!!!!
Thanks!!!!!!
geposted Mon 31 Mar 08 @ 3:00 am
Ask yourself this question instead: Do I like AMD or Intel?
It doesn't matter which one you choose.
geposted Mon 31 Mar 08 @ 7:26 am
I second antileon. Pick the one you like but remember, the performance of the overall PC it is not only in the CPU... the Motherboard its a very big factor.
I personally preffer Intel CPU with Intel brand motherboard.
geposted Sun 06 Apr 08 @ 11:00 pm
