Forum: Old versions
Topic: cant open mp3 encoder - Page: 1
what do i do everytime i try to rec. it saids cant open mp3 encoder
geposted Mon 31 Mar 08 @ 12:10 pm
I get that, so I record in Wav format, then convert the recording/File back to mp3 after,
it's a ball ache but it works.
Jimmy b
Hi jimmy, do u have the lame Mp3 encoder installed on ur PC?
If u have it. once in record config, select MP3 n choose where ur lame dll is placed on ur hdd. If u need it i can sent it to you:)
Or u can download it here from free-codecs.
This goes for u too tech6384;)
Come to think about it I don't think I have, SpinnaJ. Whenever I've to record in mp3 format, it comes up with lame mp3 encoder error.
Can you send me it please. I'll pm you my Email address.
Cheers mate :)
Jimmy b
I received ur PM. Will sent it to you once i back at home much later;)
Hi Juan, I already sent it to u n do follow the instruction in the email.
Njoy;)
SpinnaJ,
I've been having the same problem, and nothing is working!
Once you download the lame dll, what do you do next?!
thx!
Nicole
thx!
Nicole
Hi nicole, the general answer is already given above;)
hey man i do everything as you told above but it keeps on telling me cant open mp3 encoder...
i have unzipped the encoder in the vdj folder in my documents and i save my file in the same folder but the result is the same
please help
thnx in advance
nobody???
somebody please its urgent
Post the link to the download for the encoder here.
DEAR FRIENDS OF COMMUNITY:
AT 1ST I HAD THE SAME PROBLEM WHEN TRYING TO RECORD: "CANT OPEN MP3 ENCODER"
PLEASE, TRY TO FIND THE SOLUTION AT PAGE 57, AT THE USER GUIDE.pdf, ON ACROBAT READER.
- AT FIRST, YOU MUST CLICK ON THE BUTTON "RECORD",
- 2ND, CLICK THE BUTTON CONFIG, BELOW;
- THE WINDOW "RECORD AUDIO CONFIG" WILL OPEN TO YOU;
- SELECT "MP3" AT THE BOTTON OF THE WINDOW;
- THEN YOU MUST FILL INTO BLANK, THE NAME OF THE ENCODER. SO, CLICK THE BUTTON AT RIGHT (...), TO BROWSE THE NAME OF THE ENCODER. YOU WILL FIND THE CORRETC ENCODER IN: "ProgramFiles\VirtualDJ\Pluginsllame_enc.dll"
.Select it.
- Finally, note that the local above, is exactly as shown on page 57, in the user guide.
I had done these steps and now I can record mp3 format.
Good Luck and enjoy this beautifull software!!!
CLAUDIO ZACCUR
RIO DE JANEIRO - BRAZIL
.Select it.
CLAUDIO ZACCUR
Perfect EXPLANATION , Claudio , Thank You!
.Select it.
CLAUDIO ZACCUR
Bravo! thx alot, ur awsome hahahahahahhah
a friend of mine was messing around with my virtual dj program and messed my mp3 encoder up he erased it thinking it was a file to place the mixes in. how do i retrieve the code back cause now it says mp3 encoder error
If the file been deleted, you may just download at the given link at several post above;)
95%
