Hi,
I just wanted to know if there is a way to print out a playlist after a gig to have a look what at I played and and maybe make a note of what goes down well or not.
Thanks in advance,
Pete
Thanks in advance,
Pete
geposted Tue 01 Apr 08 @ 6:01 pm
export it as a text file, then print the text file
geposted Tue 01 Apr 08 @ 6:51 pm
Actually you don't even have to export it....
Create a shortcut on your desktop to the My Documents -> VirtualDJ -> Tracklisting folder
Right click on the appropriate playlist and choose the Open With.... (if the Open With does not show up, hold the shift key down when you right-click)
And Open With... Notepad
geposted Tue 01 Apr 08 @ 7:53 pm
Thanks, will try it when I get home
geposted Wed 02 Apr 08 @ 3:13 am
another alternative is open it in winamp (latest version available from www.winamp.com ) then export it to html by doing the following:
- in playlist window click on the "MISC" button; choose "Misc" option then "Generate HTML Playlist"
geposted Fri 04 Apr 08 @ 3:43 am
