Ok So I have VDJ 4.3 and just purchased the Hercules MK2 and also two Technics SL-1200
When I hook the tables up I keep getting the error in the ASIO drivers everytime I config VDJ for the tables
It works fine with just the MK2 and output to my system, once the tables are hooked up and I can the config to timecodes-2 they are not reading properly
The right deck is joggy and not playing at all..
I have re-installed the Hercules MK2 drivers and am still getting the same error message.
What do I need to do to fix this issue, Thanks
geposted Sat 05 Apr 08 @ 7:08 pm
Ok so u have v4.3, i would suggest u register ur serial if u own the pro version n grab the latest version of VDJ v5.07.
Before u open vdj, go to the herc control panel n select asio. Also in performances config select slider to fastest n latency auto. Uncheck safe mode n overclock (play ard with this).
geposted Sun 06 Apr 08 @ 1:41 am
