I am looking for a case or cases for the following:
Peavey PV 900 Amplifier - Height: 3.5" (8.9 cm), Width: 19" (48.3 cm), Depth: 15.5" (38.0 cm) Weight: 40lbs (18.2 kg)
Behringer Xenyx 1222FX Mixer - Dimensions (H x W x D): Approx. 97mm (3 7/8") x 345mm (13 18/32") x 334mm (13 5/32") Weight: 3.80kg (8.38 lbs.)
If anyone knows of a suitable unit that could accommodate either or both of these pieces of equipment can they post link(s) here. Cheers.
geposted Wed 09 Apr 08 @ 4:49 am
check out http://www.marathonpro.com/maflrecama1.html
they have lots of other selections also
basically you want a small rack that also has a slant top.
u will need to buy the brackets for your mixer also.
http://www.roadreadycases.com
geposted Wed 09 Apr 08 @ 10:17 am
Remember you can always give your specs to a flightcase company and if they don't have one in stock thay can make one up for you.
geposted Wed 09 Apr 08 @ 2:04 pm
They look the business! Thanks so much, Shane
geposted Thu 10 Apr 08 @ 2:41 pm
This company I found sells well flight cases, you can click into
They design different types of flight cases in factory. All wholesale at the reasonable price and made with best materials.
They can also product custom flight cases depends on your needs.
_______________
Moderated.
Please read our forum rules first
_______________
Moderated.
geposted Wed 05 Jun 13 @ 2:50 am
