I can't launch my newly purchased virtual dj application because I get an error message saying, "Protection error %i.
geposted Wed 09 Apr 08 @ 9:00 pm
It because u trying to use "bad" version. N currently there no mac demo.
If u have purchase VDJ Pro do FIRSTLY register n get the latest updates. Download it n then if problem persist, do contact support.
geposted Thu 10 Apr 08 @ 12:27 am
Thanks. I'll try this, but what to you mean, "bad" version? I downloaded the mac version after i made the purchase. I was given a serial number and receipt also, but the application would not launch. Do I need to erase it before I follow your recommended steps?
geposted Thu 10 Apr 08 @ 7:36 am
Hi welcome to mac community n as mac user djlongside.;)
The error maybe have to do with the prior version that u may have installed on ur mac. N if there is one, i would say go n remove it completely. I meant that unofficial version as bad. But If there are not, my apologies.
Have us sorted this out or it still have protection error? Try redownload n if still the problem persist do contact support.
Regards.
Regards.
geposted Thu 10 Apr 08 @ 8:25 am
As a registered user if it still says protection error , please delete the preferences file.
yourcomputer/users/youname/libary/preferences
its called com.atomixproductions.virtualdj.plist
Then run VDJ again and all will be fine.
Protection errors stem from having the old betas installed it is a piracy prevention system.
geposted Thu 10 Apr 08 @ 10:03 am
I get same error message but on pc ? Any ways to remove that aswell ?
geposted Tue 20 Jan 09 @ 8:56 am
Pls contact support and they able to help u on that;)
http://www.virtualdj.com/contact/index.html
Regards;)
geposted Tue 20 Jan 09 @ 11:25 am
I did everything, but the isn't it in the folder preferences... I reinstalled now some times, but it doesn't work.
Thank you for your help.
geposted Thu 13 Jun 13 @ 8:54 am
This is an old topic from 2009.
If you get a protection error, then you will need to contact support: http://www.virtualdj.com/contact/index.html
Otherwise, try a clean re-installation of the software: http://www.virtualdj.com/wiki/How%20do%20I%20perform%20a%20clean%20re-installation%20of%20the%20software.html
If you still have problems, please open your own new topic clearly explaining what you problem is, what error messages you get, etc. Click on the pen and paper icon at the top of the main forum topic list to open a new topic.
[Old topic from closed]
geposted Thu 13 Jun 13 @ 9:42 am
