Author: george2008
Ive Downloaded this skin twice to check that problem wasnt in download
The Skin Installs in 5.07 but when you try to use it it throws up this msg.....
Invalid skin file (error line 0 in the xml )
in xml editor throws up this msg.....
In Validity Test.. This is not a Valid doc
0x0050 /2D20
(fatal error) Cool%20Player.xml (2-12-109) Invalid character
Not Sure who to inform so hope this gets to right person :)
Author: george2008
0x0050 /2D20
geposted Wed 16 Apr 08 @ 7:13 am
Tries it: Extract xml and bmp from the file zip and place in directly in the skin. file if she(it) works, it is enough only to restart your comp
geposted Wed 16 Apr 08 @ 6:38 pm
Nitebeatdisco - Thanks for the post. That is a bad skin - coded for AtomixMP3 not VirtualDJ. - It has been removed. Again, Thanks.
geposted Sat 19 Apr 08 @ 7:58 am
my account george2008 is my borther in the cry
geposted Tue 14 Jul 09 @ 9:02 pm
