Hi i have been having a little problem with sound quality whilst using my herc. as a sound card / dj controller.
Im not sure wether its my herc. (mk2) or my sound system.
Basically for a while my herc works fine, playing songs through itunes or while i use VDJ. I plug it into the USB slot and then plug an external lead from my hi-fi to the 1/2 output. Usualy it works fine but then after a while the sound goes really really low and it wont play loud, when i put the volume right up i hear a white noise in the background from the speakers.
When i take out the controller and plus the external lead from the hi-fi right into the headphone slot on my macbook the sound works fine and the system is back to normal.
This is the second major problem iv had with my MK2 :(
All help much appreciated!
Cheers,
Psytramp
Cheers,
Psytramp
geposted Thu 17 Apr 08 @ 9:20 am
