Ok do i have to buy the Numark Virtual Vinyl box to make the timecoded vinyls sync with my turntables & laptop or i just have to buy the Maya44 and a external soundcard. Give me a quick and affordable list of what i need to buy to make it all work together.
geposted Tue 22 Apr 08 @ 3:40 am
Here's what you need to get timecode to work:
A soundcard that has 4 in's and 4 outs (Maya and Box included with Virtual Vinyl have that)
Timecoded vinyls (Numark Virtual vinyl comes with them or you can buy individually from this site)
Virtual DJ Software/Virtual Vinyl Software (The same software different packages)
I have never priced the two options competitively to say which is cheaper but both will work great. Virtual Vinyl set is an all-in-one solution while buying from this site you need to make three separate purchases.
You'll also need turntables and a mixer of course.
geposted Tue 22 Apr 08 @ 2:04 pm
