I just recently brought the Virtual DJ program, and im no sure how to set up my lab top to come PA speakers..
What hardware do I need?
Would the Numark Dj|iO work? If so what else will I need...
Thank you..
DJ DBK
Thank you..
DJ DBK
geposted Mon 28 Apr 08 @ 7:13 am
The DJ.io would be great for a main output and headphone output aslo.
It is quite simple to setup , you would need to register you VDJ here to get the latest updates.
geposted Mon 28 Apr 08 @ 3:56 pm
Thank you
geposted Tue 29 Apr 08 @ 12:44 am
What if I get the DXM01USB and some sort of amp, then i will be able to play out of some pa speakers correct?
geposted Tue 29 Apr 08 @ 1:05 am
Yes
geposted Tue 29 Apr 08 @ 8:03 am
Yes you could buy the full cue and this mixer , each deck is a sound card in its self so you would use two card mode.
geposted Tue 29 Apr 08 @ 3:28 pm
Thank you
geposted Tue 29 Apr 08 @ 7:23 pm
