The database is corrupt. The Mseeage I have received whithin the database: XLM page cannot be displayed.
Invalied character was found in text content. Error Processing resources *file:///C:Doucument And Settings/Administrator
Also is says
not view input using XSL style sheet, Plesae correct the error and then click the refresh button and try again.
I have save this data base in a different folder in my C Drive.
VDJ has been reinstalled and so far is workng fine with its new database it made.
How can I repair my previous database to get back all my cue points and virtual folders, which will save hours and hours of work.
Thank you ahead of time for any help
Tommy
Also is says
Tommy
geposted Tue 29 Apr 08 @ 6:20 am
I am using VDJ 4.3
geposted Tue 29 Apr 08 @ 7:02 am
Please go here - https://virtualdj.com/addons/view.html?type=tool&page=2
Download the -- runVDJ - XML Database Validator, Backup, Repair Tool
Please follow the included directions in the README file that exists when you extract the files.
** You need to put the "bad" database back in the appropriate folder before you use this.
geposted Tue 29 Apr 08 @ 11:26 am
I ran the XML Database Validator, Backup, Repair Tool. Unfortunately it diid not work. Is there anything else I can do.
geposted Tue 29 Apr 08 @ 7:32 pm
Did you put your old database back and follow the instructions for the tool ?
What were the results ?
Also, please do not post the same question in multiple forums next time.
geposted Tue 29 Apr 08 @ 10:16 pm
Sorry about the multiple postimgs just frazzled about all the wok I have to do to get back up.
I put the old database administratorXML file in C:/Program File/Virtual DJ and followed the directions. Ran the XML Database Validator, Backup, Repair Tool.
When I open VDJ it tells me databse is corrrupt.
Can you explain what is the VirtualDJ Database (<<Your winName>>).xml
Is it the same as VDJ database administrator xml
What else should I do to repair the databse
Tommy
Tommy
geposted Wed 30 Apr 08 @ 6:08 am
I sent the attached file thru aol.I am not sure how to do it with the Administrator account.
Hope that you can receive it and it is not an inconvenience.
Thank you again.
Thank you again.
geposted Wed 30 Apr 08 @ 6:32 pm
Please check your email ....
Save the file to your C:\\Program Files\\VirtualDJ folder - replacing the file that is already there.
geposted Wed 30 Apr 08 @ 8:12 pm
Thank You , Thank You, Thank You SO Much.
You Saved the Day, and to make a good party to come this weekend.
Chris you know your stuff.
Tommy
Tommy
geposted Thu 01 May 08 @ 1:23 am
You are welcome, have fun this weekend.
geposted Thu 01 May 08 @ 5:35 am
