I have just downloaded a free trail, and will buy if i can get this to work, the latest Virtual DJ. It has everything i need and i have already worked out how to broadcast, but i don't know how to make the microphone work.
On broadcast config it is set to master + Mic and that's as far as i get.
Please help, Thanks
Please help, Thanks
geposted Thu 01 May 08 @ 9:59 am
Do you have the microphone selected in your system control panel? Start>Settings>Control Panel>Sounds and Audio Devices, make sure the microphone is selected, and it is the same one your using. Hope that helps...
geposted Thu 01 May 08 @ 10:07 am
This is the problem that I'm running into as well. I am just trying to record to MP3 using VDJ ... and I have the Hercules RMX edition. When i try to record, it picks up everything except the mic that I have plugged into the RMX. Does VDJ just not recognize the microphone plugged into the RMX or am I missing a setting?
Thanks!
Thanks!
geposted Wed 03 Sep 08 @ 10:50 am
