Hi all, I'm fairly new to Virtual DJ and loving it, however (this has happened a couple of times) the sync button lights up (as if I've pressed it) and won't go out when I click it. I'm not quite sure how this happens but the only way to reset it is to close VDJ & re-open. It causes a problem as the 2 channels are linked. It won't reset by double-clicking in the middle of the sliders either (as normal)
Please help, this is really bugging me.
geposted Fri 02 May 08 @ 9:54 am
quick fix jammy, go into config > keyboard shortcuts > check disable shortcuts, should do the job...
Tayla
Tayla
geposted Fri 02 May 08 @ 12:33 pm
there must be a shortcut set for the command, from the shortcut menu you can change or disable/delete the shortcut. that used to happen to me, i had tab set as beatlock(which i never use, but had it set) and i had hit it with a fat finger a few times and i could not remember that tab was a shortcut.
geposted Fri 02 May 08 @ 1:49 pm
If u have that problem again n if u dun want to disable other shortcut, just press B on ur keyboard.. It will enable n disable the beatlock feature:) Or u can go to setting n just change that.
geposted Sun 04 May 08 @ 10:52 am
Thanks people, really helps.
geposted Mon 12 May 08 @ 5:01 am
