I use the EKS Xp5 which one of the VirtualDJ users mapped and put up in these forums, but I want to set one of the buttons to change the active deck that it controls (I only have one controller).
What is the command key in the mapping section to do this?
Thanks
Thanks
geposted Thu 08 May 08 @ 4:02 pm
Which version are you using??
geposted Thu 08 May 08 @ 4:10 pm
I am using version 5.0.
Does this have the capability?
Thanks
Thanks
geposted Fri 09 May 08 @ 3:01 am
Deckcontrol ->select (on active deck)
geposted Sat 17 May 08 @ 3:14 am
Thanks
Thanks
Please try the latest demo or add your serial so you have the latest version.
geposted Sat 17 May 08 @ 4:45 am
