When I go to the downloads section and it asks for my password.. I enter it in and I get the following messgae:
No license found. You can buy VirtualDJ or update your profile and enter your serial number in the required field.
So I go to "update your profile" and enter my serial I get the following messgae:
- Numark VirtualVinyl: this serial is already registred -
I have never had this problem before. Any ideas?
Also is there any way to change my "Identity" login?
Thanks
Thanks
geposted Fri 09 May 08 @ 3:57 pm
looks like you have sorted this.
You cannot change your forum accounts name and you cant use the serial more than once.
geposted Fri 09 May 08 @ 4:38 pm
