Forum: Old versions
Topic: To lazy to search the forum...
I'm to lazy to search the forum, and the fact of the matter is, I shouldn't have to after spending $300 on this software....
1) When will the sound and video effects be available? If they are, how do you get them?
2) Is there a wide screen skin for VDJ? I don't like how it's small on my Macbook.
3) How do you have it scan or rescan your Itunes library and BPMs? Is there a way it can scan the library in MegaSeg?
4) I'll stop being a pain in the a$$ ... Thanks in advance.
geposted Sun 11 May 08 @ 1:16 pm
Sorry to here that...
Can I offer you some donuts with that coffee?
Same place you would get the PC plugins. Btw, the ones for MAC are the ones that installs.
Same place you would get any other Skin and Yes there are Widescreen skins available.
Same as in PC version. And no to MegaSeg.
Great. Well did you get the cheese you needed ?
Hi Speed...
1) Some of the sound n video effect have already been there a mths or so. Pls check them.
2) As it been already discussed alot of time, u could use the "zip" trick from PC to Mac.
Or u could look ard at the skin downloads.. some of them have been repackage in DMG.
https://virtualdj.com/forums/86598/MAC_Version_Technical_Support/MAC_Skins.html?page=1" rel="nofollow" target="_blank">Read this thread for more details.
3) Not sure abt this as i rarely use from itunes in VDJ but i would say as normal procedure.
4) ok..lol..have a nice day.
Regards;)
Thank you for your help. sorry for being a pain. ...
cstoll. .. Donuts actually sound pretty good.
Why is it when a Teamer does say something, it's always so negative? Nice respone spinnaJ.
It wasn't negative and SpeedDemon29 didn't take it as such. He took it as a joke as it was intended.
