What is the best skin for outdoor events? We have a ton of events outdoors and the default screen can't be seen in the brightness of outdoors, even under a canopy in the shade.
geposted Tue 13 May 08 @ 12:59 pm
geposted Tue 13 May 08 @ 1:19 pm
i found if you edit a skin by inverting the colors on the .BMP since most are made for dark settings by inverting you create the opposite ... a skin for bright settings. You have to play around and see what you like.
geposted Tue 13 May 08 @ 1:28 pm
? How do you edit a skin by inverting the colors on the .BMP.. I would like to try this.. I also do outside party's Thanks!!
geposted Tue 13 May 08 @ 1:40 pm
go into the vdj skins folder, unzip the skin.zip file of your choice and you will get a .bmp and a .xml file. open the bmp in an photo/graphics editor and select invert colors. The skin may look bad so you will have to experiment with ones you like to see what is best.
geposted Tue 13 May 08 @ 2:29 pm
If you have a grey or black background and white text how does inverting the BMP change the color of the text?
geposted Tue 13 May 08 @ 4:58 pm
geposted Tue 13 May 08 @ 8:04 pm
Most of us work outside sometime. There is a huge need for outdoor friendly skins!
I would love to see some daylight skis posted in Downloads!
geposted Wed 14 May 08 @ 4:11 am
geposted Wed 14 May 08 @ 9:02 am
I just did that for an example but i will i can make it if you like. I was actually thinking of making the title/artist time/bpm all black for both becks as well as the browser text. That way you would see them very clearly on the white background. The overlap waves show up as blackish anyways so i think the rest of the color scheme would work just fine.
You want outdoor skins?? you got it. ;)
geposted Wed 14 May 08 @ 12:18 pm
Cool mate, give us a shout when it's ready :)
geposted Wed 14 May 08 @ 12:39 pm
outdoor skin is ready https://virtualdj.com/addons/skin.html?id=4416
geposted Wed 14 May 08 @ 6:11 pm
Nice 1 mate
geposted Thu 15 May 08 @ 9:27 am
I got lazy with the preview, it actually look better in use. I made all the text black for each deck. I dont really know if anyone would like it but it is what is.
geposted Thu 15 May 08 @ 9:43 am
Well I've got it now, and I've just taken my lappy outside and it works. It does exactly what it say's on the tin.
geposted Thu 15 May 08 @ 9:56 am
Thanks Listen2!
Nice option for us "occasional outsiders!"
geposted Thu 15 May 08 @ 2:19 pm
your welcome!
I was debating if i should darken the overall tone a little bit. Make it more gray and not so "hot white". I dont know.
geposted Thu 15 May 08 @ 3:12 pm
I'm not sure, but maybe tinting will lessen the desired effect on LCD lappy screens...I dunno, maybe try and see on a nice, bright day ;)
geposted Fri 16 May 08 @ 12:00 am
I tried to change the skin that i use, can't get it right... can you help me with it? I use the DAC 4.3 skin....I think I'am doing something wrong..THANKS!!
geposted Tue 17 Jun 08 @ 8:23 am
What are you doing?
geposted Tue 17 Jun 08 @ 11:41 am
