hey everone.
Within the next little while, im going to be changing over to a new laptop.
The problem is that atm, on this computer, i have all preset cues, and when i trasfer the songs, the cues dont come along with it.
is there a way to export all the cues? is there a file i am suppost to move with it?
thanks!
thanks!
geposted Sat 17 May 08 @ 12:58 pm
Copy your database XML from old system documents file and paste it onto new system.
Ver 5 database located in documents/ virtual dj
geposted Sun 18 May 08 @ 7:39 am
And if you are using Numark Cue, the file is "NumarkCue database.xml" located in My Documents.
geposted Sun 18 May 08 @ 8:56 am
