Can i use my M-Audio Oxygen 8 and set it up to control certian paramaters of the mixer... because this moving one thing at a time with the mouse isnt cutting it....
geposted Sat 17 May 08 @ 1:59 pm
I think you can as it is a MIDI device, you can try to map it yourself, go to "Config>Remote Control>General MIDI>Config".
geposted Sun 18 May 08 @ 9:22 am
Anyone figure this out? I dont see those options???
geposted Tue 22 May 12 @ 1:45 pm
Those options won't be there if you're using the home free version.
Keith
Keith
geposted Tue 22 May 12 @ 3:02 pm
These options aren't available any more because they are obsolete (This topic is from 2008 and over 4 years old!)
In the latest version, MIDI controllers can be accessed CONFIG -> Mappers but usage is limited to 10 minutes at a time in VirtualDJ Home FREE.
To use MIDI controllers for more than 10 minutes, you will need to purchase the full VirtualDJ Professional: http://www.virtualdj.com/buy/index.html
For info on how to map a MIDI controller, please see our FAQ pages: http://www.virtualdj.com/wiki/How%20do%20I%20map%20my%20MIDI%20controller.html
[Old topic from 2008 closed]
geposted Thu 24 May 12 @ 7:16 am
